Indicates that an attempt to collect tech support report for a collector failed. collector: Hostname or IP address of a tech support collector port: TCP port number that the collector is listening dataset: Data set configured for the collector reason: Failure reason
This is an unexpected internal condition needing technical assistance. Contact technical support with the following information: output of 'show tech-support', and 'show tech-support collector'.
Error
Failed to collect %dataset% tech support report for the collector %collector%:%port% (%reason%)
| Name | Type |
| collector | String |
| port | uInt32 |
| dataset | String |
| reason | String |
